hi,
i am using a thdb ada daughter card for converting a analog signal to digital which is 14 bit . it is giving a unsigned output. i need to multiply it with another sin wave which will have the same frequency. i got few quires
above figure i cached form signal tap logic analyzer, here first siganl (ADC_DA) is multplaying with x_out and y out which is sin and cosine signal and middle two are the outputs. my problems are
1:: i need to use signed calculations here, but the sin signal at 800 khz (ADC_DA)from the adc card is showing like attached image above.
how can i
covert that unsigned output to a signed output which will looks like a sin wave?. if i apply unsigned line chart in signaltap for adc_da , then it
exactly looks like a sin wave, so it will create a problem in signed calculation right? can anyone got a solution for this? else its ok to multiply .
2:: what will happen when two sine waves multiply digitally what will be the expected output. say if i multiply 800khz *800khz sine waves (both are in
binary values ) in an fpga, what will be the possible output?
any help is really appreciated.
thanks and regards
