adc conversion rate doubt
rameshbalan
Member level 2
Member level 2
Is there any formula for finding conversion rate of ADC, how to relate the conversion rate with others.
Are you asking ADC Conversion time Refer the micro controller datasheet
For ADC Resolution=Max. Voltage/ ADC bit
Vin= (ADC value*Max. Voltage )/ Max. ADC value
ADC value= (Vin*ADC max Value)/ Max. Voltage
I hope its helps you.
I hope that you are asking for the speed of the ADC conversion. It may vary with type of ADC.
yes. i need the conversion speed of delta sigma adc related with the resolution of adc.
thanks
is there any formula to find the conversion rate of the sigma delta adc.
I try to answer as specific as your question:
"Yes"
Klaus
