aminpix
I have a design with max19507. It seems the default analog input (ADC input) is between 0.4 and 1.4V. (I have connected IN- to ground and IN+ to the input signal.)
Is there anyway to change the input analog range to 0 - 2.5v? In page 15 of the datasheet it has been described but I am not sure I understand it or not. If I connect REFIO pin to 2.5v the voltage range will change to 0 - 2.5v?
Am I right?
Here is the link of the datasheet
https://datasheets.maximintegrated.com/en/ds/MAX19507.pdf
Am I right?
