flote21
Advanced Member level 1
Hello everybody, I am facing an issue with the following ADC: ADS7138...
See below my schematics:
I was able to communicate with the part because adter sending the next command: RIB 0x2E 0x1000 1 => Result: 0x81
However after sending the next settings to configure the ADC in a manual way, I alwas read 0x00 in all the channels (I have already checked that the input voltage on AINXX are in the range of 1V - 1v8 :
1) All AINxx configured as Analog inputs:
WIB 2e 0805 00
2) Send the calibration command:
WIB 2E 0801 02
3) CON_MODE = Manual:
WIB 2E 0804 00
4) SEQ_MODE = Manual:
WIB 2E 0810 00
5) Select Channel to read (AIN0):
WIB 2E 0811 00
6) Read the register of AIN0:
RIB 2E 10A0 1
Result=0x00 for all the AIN. I have tried to enable the FIX PATTERN register (WIB 2E 0802 80) and I read always 0x00 too.
Any idea about what is going on?
Thanks in advance.
Greetings.
WIB 2e 0805 00
WIB 2E 0801 02
WIB 2E 0804 00
WIB 2E 0810 00
WIB 2E 0811 00
RIB 2E 10A0 1
Thanks in advance.
Greetings.
