Hi again
As you probably know , each Rectifier , with capacitor , will make high value of reactive power . hence , you have to use a PFC , after your rectifier and capacitor , it will improve the current waveform , to achieve , cos phi = nearby 1 .
So , a boost converter is incredible for it .And as i told you at past , if you need higher power and voltage , it is simple , you just need to add an opto coupler , and then it will connect the out put PWM , into a high power mosfet , e.g IRFP450 or IRFP460 , thus it can handle this rage of power easily . then you can create a feed back loop after that simply .
Best Wishes
Goldsmith
