Accelerate design performance with HDL coding practices
elec_student
Member level 1
Member level 1
Can anybody give me any support domuments or comments for the same.
Thanks in advance
There existed something called openmore: guidelines for HDL coding. I did an assignment back at the Uni to qulify an IP according to those guildelines. The guidelines were very usefull : You can find them here:
http://www.vlsiip.com/ipba.pdf
Kr,
Avi
Look into few book like Synthesis By Douglas Smith. That will defenetly help u for coding techniques
I am not able to open this pdf. Can u plese post it here?
Hi, Here it is:
This is actually a report of evaluation of an IP against HDL coding guidelines.
You might want to read the whold document, which states first the guide line in a table, and then states how far the IP follows that guideline.
If you only want to see the guidelines, then you can browse through index of tables. Each table corresponds to one unique guildeline
Hope it helps,
any more questions? most welcome
Kr,
Avi
Hey I am facing negative slack in my design. I want some documents or tips which can help me in optimising code. This document was not helpful in this regard.
