ehsantech
Member level 3
- Joined
- Jul 29, 2014
- Messages
- 67
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 492
Hello
here is my program and settings
As you see the simulation settings I want to see voltage output of each nodes @60Hz.but here is my output file information:
but I got voltage of each node zero.
what is my mistake?
**** INCLUDING SCHEMATIC1.net ****
* source PHASORE
R_R1 N00149 N00092 1k
L_L1 N00092 N00096 2mH
C_C1 N00096 0 3uf
V_V1 N00149 0 DC 0Vdc AC 4Vac 10
**** RESUMING wow2.cir ****
.END
**** SMALL SIGNAL BIAS SOLUTION TEMPERATURE = 27.000 DEG C
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
(N00092) 0.0000 (N00096) 0.0000 (N00149) 0.0000
VOLTAGE SOURCE CURRENTS
NAME CURRENT
V_V1 0.000E+00
TOTAL POWER DISSIPATION 0.00E+00 WATTS
what is my mistake?
