ac sine wave to dc square wave 0-5 volts
fang
Newbie level 1
Newbie level 1
Hey guys, you'll have to lead me through this. I know nothing of diodes etc. My background is 12 volt DC automotive stuff.
My hot rod has a GM 700R4 transmission with the GM vss running an autometer electric speedometer. The vss has 2-wires, and generates a four-pulse (4000 pulses per mile) sine-wave (A.C. current) with minimum voltage of 1.8 volts and the signal climbs proportionately with vehicle speed.
I would like to convert the AC sine wave to a DC square wave with a voltage of 0-5 volts (most senors are 0-5 volts on computer equiped cars) so I can connect my innovate LM2 to it so I can record MPH along with the AFR and RPM that the LM2 records. The LM2 has connections for analog input and output. The LM2 already does this through an OBD2 connection but this hot rod has no OBD2 connection as it has no ECM.
This is not something that will be mounted permanently in the car if that helps.
Thanks for all your help guys!
There are many easy ways to convert a pulse to DC but hand-holding someone with no experience about EMI and signal characterization, might be beyond me.
. I am not sure of the shape of your ac pulse, the source impedance and if it is floating or grounded.
If you can answer this, perhaps a diode clip circuit, and fixed gain amplifier with hysteresis input and 5V CMOS output will work . It may need some small filter on the input.
Not knowing what waveform your sensor puts out...
If it is simple as this schematic, then a single diode will convert it to positive polarity.
The diode will subtract 0.6 V from the incoming signal voltage.
The zener diode is included as a safeguard, in case your next device should not be exposed to greater than 5V.
It will be a further challenge to adapt the waveform for use by your next device.
