mutlu_sgul
Junior Member level 1
igbt bridge
Hello Friends...
Nowadays I am working on Three Phase Induction Motor Drivers. I have constructed a simple one and see it when it's runnig. I have used a Fuji IGBT module have 6 IGBTs max Ic current is 15A. I have connect the Microcontrollers pins to the optocouplers (CQY80) and then the emiter of the transistor of the optocoupler to the IGBT's base terminals. I have used 4 different 15 V power supplies to switch base terminals of lower leg and each base terminal of upper leg. I have write this simple code and download it to the microcontroller. I used AT89S52 in this project.
///// THAT IS THE CODE ////
#include <regx52.h>
#include <lcd.h>
#include <stdio.h>
void Delay (long int sure)
long int j,q;
for (j=1;j<=sure;j++)
for(q=0;q<=10;++q){;}
main()
long int b;
b=9;
P0=0x00;
P1=0x00;
P2=0x00;
P3=0x00;
Delay(300);
while(1){
P1=0x2A;
Delay(b);
P1=0x00;
Delay(1);
P1=0x0E;
Delay(b);
P1=0x00;
Delay(1);
P1=0x1C;
Delay(b);
P1=0x00;
Delay(1);
P1=0x15;
Delay(b);
P1=0x00;
Delay(1);
P1=0x31;
Delay(b);
P1=0x00;
Delay(1);
P1=0x23;
Delay(b);
P1=0x00;
Delay(1);
if (P0_0==1){b=3;}
if (P0_1==1){b=4;}
if (P0_2==1){b=5;}
if (P0_3==1){b=6;}
if (P0_4==1){b=7;}
if (P0_5==1){b=8;}
if (P0_6==1){b=9;}
if (P0_7==1){b=10;}
When I power up the system I saw the motor rotates and when I press buttons connected to the P0 I saw also the speed of it changes. Then I read about the AT90PWM3 and decided to use it in my AC Induction Motor Driver. I want to learn about how to use this microcontrollers PWM terminals. I read too many topics about constant V/f control. I know the method but I don't know how to confiure PWM terminals. How to get the output. If there is anybody know about this topic please helps me.
Hello Friends...
#include <regx52.h>
#include <lcd.h>
#include <stdio.h>
long int j,q;
main()
long int b;
b=9;
P0=0x00;
P1=0x00;
P2=0x00;
P3=0x00;
Delay(300);
while(1){
P1=0x2A;
Delay(b);
P1=0x00;
Delay(1);
P1=0x0E;
Delay(b);
P1=0x00;
Delay(1);
P1=0x1C;
Delay(b);
P1=0x00;
Delay(1);
P1=0x15;
Delay(b);
P1=0x00;
Delay(1);
P1=0x31;
Delay(b);
P1=0x00;
Delay(1);
P1=0x23;
Delay(b);
P1=0x00;
Delay(1);
if (P0_0==1){b=3;}
if (P0_1==1){b=4;}
if (P0_2==1){b=5;}
if (P0_3==1){b=6;}
if (P0_4==1){b=7;}
if (P0_5==1){b=8;}
if (P0_6==1){b=9;}
if (P0_7==1){b=10;}
