AC/DC adapter problem
josh777_123
Newbie level 1
Newbie level 1
my laptops original AC/DC adapter has gone bad and I could not find one swith same spec.AC i/p :220-240V,DC o/p:19V, current : 2.64A, power : 50W ......
But i can find another adapter with 18.5V DC output , current : 3.51A, power :65 W
Will the 65W power adapter with higher current of 3.51A will cause any problem to laptop, will it damage the laptop due to high current or is it ok to use this 65W power adapter.Please provide your valuable inputs on this
thanks
josh
the problem lies in the voltage your new adapter is short of 0,5 v. i think it is ok. could you adjust your new one to 19 V(may be you could open the case and look inside). hope this help
You laptop will only take the current that it needs.
As it will be a switched mode psu you are unlikely to find a pot to vary its voltage.
it is likely to work but your batteries may not get as fully charged as before.
In my opinion it will work for u`r laptop........
0.5 v is only 3 % (aprox....)
Every appliance has a minimal of 5 % variation acceptence for volt variacion(the majority has 10 %).
Measure u`r 220 v ac..and it rarely is 220 it is 210-230....
Best of luck
LaTeX Commands Quick-Menu:
