ac current sensing circuit design
Member level 1
ShangHai,China
hello, anyone.i am designing an ac current sensing circuit for my motor control. and my problem is: how to convert the ac current into dc voltage which can be processed by mcu?
can anyone give me some advice? by the way , i want to design the circuit with integrated ic ,such as isolation amplifier..
and the ac current maybe: Vrms=15A, Frequency=50hz
thanks in advance
Ideas for ac current sensing and measurement ..............
No series resistor needed, isolation included.
Isolated Current Measurement
Regards KAK
The simplest way to convert the ac current of 0...15 A is to use a small AC transformer to which you can add one wire loop as a primary "winding". Then the other multiturn winding will generate an AC voltage, proportional to the number ratio of turns.
Use an insulated copper wire, ~ 1.5 to 2.0 mm diameter so it will not get hot with 15 passing through it. One turn on the transformer could generate up to several volts on the secondary; then you can add a rectifier diode and so you get a DC voltage proportional to AC current.
Any AC transformer can be used, with one good winding on it. Make sure you install the device in a protected insulated case with terminals; safety first!
thanks for all ur response. i will read them with my heart, u know i am just a electronics begunner.
thank u again.
