Hi all
I am designing a Sample hold opamp with cascode compensation. I have known the opamp has a pole and a zero very near. So in order to decrease the influence on settling time of doublet, i push this doublet far away from the loop BW(about 3*BW), And other high fre poles and zeroes are all largger than 3BW.
I thought if the doublet is out of the BW, it will not influence the settling time. But i found although the doulet is set as the above, they also have influence on the settling time and the settling damping.
Anyone has some suggestions about this problemns?
Thanks
