power units in primetime report
Does anyone know how the power unit in the report of Prime time is defined?
It confuses me a lot.
I wrote a module in verilog, synthesized it in DC. Then use the verilog file produced by DC, I simulated and got a VCD file. Then I use prime time to read verilog file and VCD file, to estimate power of the module, which information is recorded in a .rpt file.
But this rpt file does not show the power unit.
Is the power unit in the library the same with that in PT report?
Or is it fixed to be 'W'?
I am using 65nm library from TSMC.
If the unit is 'W', the peak power used seems too much, since it's just a small module. But if the unit is mW, the power is a little too low then.
I have checked the library file, and it says:
capacitive_load_unit (1,pf) ;
voltage_unit : "1V" ;
current_unit : "1mA" ;
time_unit : "1ns" ;
pulling_resistance_unit : "1kohm";
default_operating_conditions : WCCOML ;
time_unit : "1ns" ;
unitTimeName = "ns"
timePrecision = 1000
unitLengthName = "micron"
lengthPrecision = 1000
gridResolution = 5
unitVoltageName = "v"
voltagePrecision = 100000
unitCurrentName = "mA"
currentPrecision = 100
unitPowerName = "mw"
powerPrecision = 1000
unitResistanceName = "ohm"
resistancePrecision = 10000000
unitCapacitanceName = "pf"
capacitancePrecision = 10000000
unitInductanceName = "nh"
inductancePrecision = 100
The rpt is as follows:
Attributes
i - Including register clock pin internal power
u - User defined power group
Internal Switching Leakage Total
Power Group Power Power Power Power ( %) Attrs
io_pad 0.0000 0.0000 0.0000 0.0000 ( 0.00%)
memory 0.0000 0.0000 0.0000 0.0000 ( 0.00%)
black_box 0.0000 0.0000 0.0000 0.0000 ( 0.00%)
clock_network 0.0000 0.0000 0.0000 0.0000 ( 0.00%) i
register 0.0000 0.0000 0.0000 0.0000 ( 0.00%)
combinational 1.909e-04 6.973e-05 1.980e-05 2.804e-04 ( 3.89%)
sequential 6.864e-03 3.008e-05 3.003e-05 6.924e-03 (96.11%)
Net Switching Power = 9.981e-05 ( 1.39%)
Cell Internal Power = 7.055e-03 (97.92%)
Cell Leakage Power = 4.983e-05 ( 0.69%)
Total Power = 7.204e-03 (100.00%)
X Transition Power = 0.0000
Glitching Power = 0.0000
Peak Power = 0.2558
Peak Time = 4890.000
