fft - Fast Fourier transform
Syntax
Y = fft(x)
Y = fft(X,n)
Y = fft(X,[],dim)
Y = fft(X,n,dim)
= fft(x) returns the discrete Fourier transform (DFT) of vector x, computed with a fast Fourier transform (FFT) algorithm.
If the input X is a matrix, Y = fft(X) returns the Fourier transform of each column of the matrix.
If the input X is a multidimensional array, fft operates on the first nonsingleton dimension.
Y = fft(X,n) returns the n-point DFT. fft(X) is equivalent to fft(X, n) where n is the size of X in the first nonsingleton dimension. If the length of X is less than n, X is padded with trailing zeros to length n. If the length of X is greater than n, the sequence X is truncated. When X is a matrix, the length of the columns are adjusted in the same manner.
Y = fft(X,[],dim) and Y = fft(X,n,dim) applies the FFT operation across the dimension dim.
