twanlay123
Newbie level 1
Has anyone looked at xapp975 from xilinx? It is at
https://www.xilinx.com/support/documentation/application_notes/xapp975.pdf
It is a solution for In-system programming, has anyone used it to program the XCF32P successfully? I try to use it, but not successfully, always failed in the verify operation.
I want to ask some questons.
1. Is the CRC value in the .hex file, which the PFP module uses to verify the programmed PROM contents during the verification operation, is stored in little endian order like other programming data?
2. In the pdf, we can know that , after pfp module has received 256 bits of data, the PROM has to program the data into the actual Flash memory.
Is the 8-bit CRC value in the 256 bits of data, or we should send the CRC value first, and send the 256 bits of actual programming data secondly, and then wait the 256 bits of data shifted to the flash.
Thanks for help.
Thanks for help.
