a systemc user friendly simulator under win?
vaf20
Full Member level 3
Full Member level 3
systemc simulator
hello ppl.
Does ne1 khows a systemc user friendly simulator under win?
any help is highly appreciated
Thanks in advance
systemc simulator for windows
There's at least one Wndows distribution - which is easily found with any search engine.
Go to www.systemc.org, register and then you can download the latest release for any environment you like (Windows or Unix). This includes the
simulation engine and your development environment (VisualC++ or gcc) is all you need to simulate SystemC designs. If you want to view waveforms, a public domain VCD waveform viewer can be easily found (I can search if you want!). So, SystemC simulation is no problem! Did you mean synthesis? Because then, I am also interested!
Hi:
I read the SystemC document it says that
C++ to HDL conversion is done manually.
I wonder is there any too-chain to do that without human interaction?
As much as I know about Synopsys SystemC compiler, you must model your design at the RTL level if you want to generate Verilog netlist from SystemC code. If you model your design at higher levels than RTL you must manually refine your model. I am not sure whether there exists commercial tools that can performs tasks like High-level Synthesis (Behavioral Synthesis) using SystemC as input description.
There exists other commercial tools that support SystemC.
yes,visual elite support systemC.any other tools?
Xilinx ISE also supports systemC and handel-C
LDV50 Contains NC-SystemC which can simulate SystemC
visualelite from Summit Design
Really :!:
What's OS? Win or Linux ?
I think only , solaris port is available currently , with linux comming soon , but no info on windows ...
Re: systemc simulator
Right now all the top three EDA vendors have SystemC simulator.
. Syn@psys: vcs + SystemC co-simulation
. C@dence : NC native SytemC compiler (SystemC can be another native language supported by NC simulator)
. Ment@r : modelsim5.8 supported SystemC compiler
modelsim5.8 easy to use.
.vcd convert to .WLF
vcd2wlf <source.vcd><target wlf>
Modelsim 5.8 under windows doesan't support SystemC as far as i know
