a question with differential amp and cmfb
wdd
Member level 3
hello, guys,
I have designed a diff amp with SC-cmfb, the phase margin need to be opitimized,
when i do ac simulation, the SC-cmfb should be took out, so my question is whether the capacitor in SC-cmfb be one part of Cload??
thanks a lot.
B&R
wdd said:
hello, guys,
thanks a lot.
B&R
Yes, because SC-cmfb introduce some loading effect to your diff amp. Actually SC-cmfb is a kind of switching load, which is not purely capacitive, its effect to your amp also depends on the switching frequency.
    wdd
thx hylas,
do you have some papers or document relevant?
B&R
I don't have any references. But you may try in this way:
Assume the switching frequency of the SC-cmfb is much larger than the bandwidth of your amp. Eg. fsw > 10*UGF
1) Obtain a low frequency model of the input impedance of your SC-cmfb circuit. Input of the SC-cmfb circuit should looks like a resistive element at low frequency.
2) add the equivalent resistance to your amplifier and see the freq response.
Hope this help.
