a question for Encounter RTL Compilier
relax1
I have a question.
I try to find VHDL codes,then put in my Encounter RTL
Compilier design to do synthesis,but the terminal shows me some error messages,
as following as:
rc:/> Setting attribute of root '/': 'lib_search_path' = /opt/cadence/local/osu_stdcells/lib/tsmc018/signalstorm
Freeing libraries in memory (osu018_stdcells.lib)
Setting attribute of root '/': 'library' = osu018_stdcells.lib
library ieee;
Error : Parsing error. [VLOGPT-1] [_read_hdl]
: in file 'alu_rtl.vhd' on line 2, column 7.
Failed on _read_hdl alu_rtl.vhd
In my file direction,I have the library of osu018_stdcells.lib,then I ran the Verilog source codes that they were successful to systhesis the circuits,then I followed to modify the rtl.tcl file to be running the source codes of .vhdl,but it showed me the wrong messages above. Is it not support .vhdl source code?Or I need to type some commands to support it? Why does not the library support the ieee of VHDL?
Would you please tell me how to resolve it?Thank you!
