bashir2000
Newbie level 3
Hello dear all,
I have run into a problem regarding the FPGA. The FPGA output signal amplitude is 3.3, and to drive my switches, I need to increase the voltage up to 15 V. I am using TC4427(dual power mosfet driver)as a buffer after FPGA , and would like to check the possibility of my gate driver, but whenever I wanna check it, the FPGA pin is destroyed. I personally believe a resistance is required in series with the IC. Could you please give me a hand with this problem if you do not mind?
I highly appreciate your prompt answer.
Best Regards,
Bashir
Best Regards,
Bashir
