zjwang
Junior Member level 1
I want to use formality to do the hierarchy verification for my design, so i use the write_hirearchical_verification_script command to write out a script, and then i source the scritp. The result told me that there is a block failed and this cause the higher hiearachical block which contains the block all failed.
But when I verify that lower hierarchical block separatly, it is success. Then why the block failed in hierarchical verification?
