A question about ADS data access component
ChineseTea
Newbie
I wanna replace the ideal inductor with the data I measured by the impedance analyzer in the ADS. Although I know that Z1P block in ADS can use an equation to equal the impedance, the actual data is hard to be approximated properly.
I search online for the file way, some people can use the DAC enable the Port impedance vary with frequency, I also try such way to make my Z1P block require same effect,but I failed.
Moreover, I usually use HB simulation and AC simulation in ADS . I don't know whether there exist the unknow effects about the simulation controller between the DAC&Z1P block as said above.
Can someone give me the solution by DAC or other file based way.
This is my first time use this forum. If I miss something important, please tell me and I will add as fast as i can.
Attach files are from impedance analyzer.
I finally find the way & answer online according to a PDF.
This PDF is a chapter of ADS fundamentals 2009 (from aglient).
I haven't found the whole book, but such chapter is helpfui to this problem.
I also wanna this whole book.
  • 6B_lab.pdf
