a question about a design of comparator!
gdhp
Full Member level 1
hi all
here i was given a dc signal voltage:0 or 1.5v or 3.3v. Based on the three
voltage, three control signals should be generated to trigger three switches.
So i think use two comparators. The trigger voltage of first comparator is 1.2.
if the out of it is high, another comparator with 2.4v trigger voltage is needed.
but the method is not good. is there another notive method?
Thank you all
no reply?
OR you can use one comparator at different times
