sunjiao3
Member level 5
Hi, dear all.
I encountered a strange problem in the multi_finger structure. In simulating a hysteresis comparator, I found that the width of the hysteresis window and the tolerence of mismatch is closely related to the number of the fingers. In addition, even the structure with the same numbers of fingers, have different simulation result. For example, a nmos, which is 10/2, is depatched into a 2*5/2 with 2 fingers or 2 mos transistors each sized 5/2. The results are different. Why?
I know it is related to the physics of the mos transistor. So, could anyone please shed light on this problem. BTW, the comparator work in low frequency, so, the Cgd and Cgs are not so important, in my opinion.
Also, is there any thesis focused on this topic? I would like to know some details of it.
Thank you very much.
