I have read this from some material:
without trimming or calibration, the resolution of pipelined ADCs is limited to 10bit. the main reason is mismatching.
what I want to know is how to make this conclusion with derivation?
does any materials about this on web?
There are plenty of papers dicussing the non-idealities of pipelined ADC. One of the major limitation for untrimed 10-bit accuracy originates from the capacitor mismatch at the MDAC stage.
There are many problem with induce error in the ADC , but the Key factor is MDAC . Capacitor mismatch ,, It's mean gain mismatching , other like
layout mismatching will increase even harmonic ...
So that if you want to well 10bit ADC , I think the capacitor value selcet is very important .
Ps , you can see the foundry's capacitor matching report
Hi
The capacitor mismatch is one of the non-idealities also the open loop gain of the MDAC affects the resolution too.
I think you want to do triming . I think you must add
the cap value , In my experiment , we do 100MHz.10bit/ADC , the first MDAC , I will use 1pf ~
1.2pf . Becasue it will get well matching ..
and you can do the post-sim , and check the parasitic cap with Cs/Cf , this is key factor in the first
stage and second stage .
The errors in ADC could be due to offset of the op-amp,cap mismatch ,comparator offset .The killer would be cap mismatch in MADC .
consider one capacitor mismatch at a time .Let's say Cs=C+/- delta and calculate residue with new cap .The residue show that Closed loop gain varies with cap mismatch .
This has be trimmed using Analog/Digital calibration techniques for first 3 or 4 stages .
Can any one highlight on Digital calibration techniques ? .
