hsuang
Newbie level 3
I need a diode with a reverse current smaller than the classic small-signal diode (as couod be a BAS16 and so on), but still common as it.
I think the best solution is using a (symmetrical?) FET with the gate as anode and source + drain as cathode...
But if I was choosing a BJT, what's the best connection? Using (NPN) base as anode and collector as cathode, should I leave the emitter floating or connected to base?
Could someone explain this subject?
Many thanks
Francesco
Many thanks
Francesco
