Jorge Jesse Cantu
Junior Member level 1
- Joined
- Mar 3, 2014
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 167
With the following specifications:
Design a 4-bit Johnson counter and decoding for all eight states using just four flip-flops and eight gates. Your counter needs not be self-correcting.
I wrote my VHDL code for the 4-bit Johnson counter, but I am confused as to what it means by decoding for all eight states, using eight gates? Do I need to have combinational logic to implement this? If so, how would I implement that in vhdl?
Here is my code:
Here is my code:
HTML:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
entity eightRC is
port(
CLK : in std_logic;
EN: in std_logic;
RST : in std_logic;
Q: out std_logic_vector(7 downto 0)
end eightRC;
architecture behavior of eightRC is
signal qs: std_logic_vector(7 downto 0);
begin
process(CLK, RST, EN)
begin
if(RST = '1') then
QS <= "11111110"; --initial state for QS
elsif (CLK'EVENT AND CLK = '1' and EN = '1') then --enable starts the shifting
QS(0) <= QS(7); --shift '0' to the left each clock edge, Q(0) gets Q(0) bit value
QS(7 downto 1) <= QS(6 downto 0);
end if;
Q <= QS;
end process;
end behavior;
