hello everybody,
I want to simulate the performance of inductors with HFSS. I found that the poly layer was not added when I read some examples. Why? Is the simulation more accurate after adding the poly layer?
And is it appropriate to only add those shield metal layers under the inductor,when I want to simulate the floating shield inductor which is some metal layers are added underneath the inductor? Is there anything else I should set up due to the shield metal layers?
