A 33-38 GHz Phase Locked Loop
Hi everyone,
I want to share with you the 33-38 GHz phase locked loop. The procduct allows implementation of fractional-N and integer N phase-locked loop (PLL) frequency synthesizer when used with an external loop filter and an external reference clock. The wideband millimeter-wave voltage controlled oscillator (VCO) design allows frequencies from 33GHz to 38GHz to be generated.
The PLL integrated VCO, prescalar, frequency divider, PFD, charge pump, fractional-N modulator and SPI interface for compact applications, and the total die size is smaller than 3mm2.
The integrated high performance fractional-N modulator ensures the output has low in-band spur and neglected out-band spur.
Control of all on-chip register is through a standard SPI interface. Also, the chip has optimized power plan for simplified external power supply.
Our product can be used in Test equipment and instrumentation and Clock generation.
Visit attachments to learn more about our product.
Thanks.
