SIP2012V network audio module 10/100M Base adaptive Ethernet interface module
sinrey
Junior Member level 1
SINREY SIP2102V network audio module is a general-purpose stand-alone SIP audio playback module that can be easily embedded into OEM products. This module decodes and plays the SIP protocol and RTP audio stream from the network.
Technical parameters​
  • power input: Voltage DC 4.7~16V
  • Maximum working current, 200mA
  • temperature: Operating temperature range Industrial grade: -20~55℃
  • storage temperature range -40~85℃
  • Network Interface:10/100M Base adaptive Ethernet interface
  • Line Out output:Load 10KΩ, typical 1000Vrms, signal-to-noise ratio 95dB (in playback mode)
  • decoding mode:provide stereo playback, up to 48kHz, 320kbps audio stream, support MP3.WAV (PCM +IMA ADPCM), G.711 a/u, G.722 and other formats.
  • The minimum delay is50ms
  • module size:Length x width x height: 5 x 5 x 1.7cm
