9.1i (XILINX) - problem with the area on FPGA
ramzitligue
Member level 1
area on FPGA
hi,
i built a component using VHDL,then i synthesize it and i found that the logic
utilization on fpga was 1000 slices
then i duplicate this component 4 times and i synthesize the new coponent and i found that the logic utilization on fpga was less than 4000 slices: it's 3500 slices
is it normal?
i use ise 9.1i (XILINX)
can you help me?
Re: area on FPGA
Its common for synthesis tools to optimize and share resources across entities or modules.
There are usually options to enable resource-sharing, as well as flattening -hierarchy, etc.
If you disable these features, then you will be able to get your 4000 slices, though you
probably don't want to do that in the long run.
Hope this helps.
Tink!
Re: area on FPGA
hi,
where can find the option to desable the resource-sharing in ise9.1i?in order to make a comparison...
Added after 17 minutes:
thanks i found it
