1icarus1
Junior Member level 3
Hi there,
I need to get up to 1500 meters (in open field) comunication link, between ADEUNIS modules. My terminals are a master which is an 869.525 MHz ASK transmitter and a slaves (ASK receiver).
The complete set of modules I used is the ARF27 from ADEUNIS and it's datasheet can be found at:
The characteristics of the transmitter (ARF7243A) are:
Operating frequency 869.525 MHz
Conducted power from 25 mW (+14dBm) to 500mW (+27dBm) on 50 Ohm at 5V
Modulation ASK
The characteristics of the receiver (ARF7246A) are:
Frequency 869.525 MHz
Sensitivity 0.5μV (-113dBm) On 50Ω
Demodulation ASK
Bandwidth 100 kHz
The complete set characteristics are:
Link settling time 2.5ms
Range in open field 2000m
Binary rate from 500 to 2400 bps Manchester
ADEUNIS suggests whip antennas to be used, for high distanses.
Personally I don't need to get the maximum, but up to 1500 meters in open field. In practice the project is a transmitter that is always moving round the receiver and sending measurements from a sensor.
I have build the master and slave circuits, following Adeunis APNote's information (modules filters, protocols, e.t.c.) and the programs are working fine.
My first test was using simple cables 86mm (λ/4), at both transmitter's and receiver's ANTENNA pin, using them as antennas. The result was to get up to 150 meters at open field. So I realized that my problem, was my antennas.
It is impossible to use other than 86mm cable at the receiver (IP66), but it is possible to use any antenna you suggest me at the transmitter module.
I have no experience on RF theory. Could you please suggest me the antenna I need (a URL could be fine) and also the distanse of the coaxial cable I have to use (I neeb at least 5 meters of coaxial cable to connect the antenna to the transmitter).
Michael.
Modulation ASK
Demodulation ASK
Bandwidth 100 kHz
Michael.
