[SOLVED] 8051F330 C Keypad programming.
Qrios
Newbie level 6
Newbie level 6
As you can see, my JP1( Keypad ) is connect to P.1 of my IC. However, the 5 inputs are used to get the signals from the 4 x 4 keypad. Out of the 5 inputs, 1 input is connected to another IC which will send me a high or low signal, high when keypad is in use, low when it is not. So my question is how will I be able to get the numbers pressed from keypad using these 4 pins? I'm using C language, SDCC compiler. Please p.m. me if you need anymore information.
Thank you in advanced.
I think P1.0, P1.1, P1.2, P1.3, and P1.4 is connected to keypad.
Yes. They're connected but since I didn't use any other P1 port, I'll just use P1 as a whole.
Will you use all the 8 pins of P1 for keypad? Then connect 4 rows to P1.0 - P1.3 and 4 columns to P1.4 - p1.7
