ark5230
Advanced Member level 3
- Joined
- Jun 29, 2009
- Messages
- 862
- Helped
- 163
- Reputation
- 324
- Reaction score
- 140
- Trophy points
- 1,323
- Location
- India
- Activity points
- 6,187
I am trying to produce delay of 1/20 s (50 ms) using Timer/counter 0.
Crystal frequency is 11.0592 MHz and machine cycle is 11.085µs.
for 50ms the machine cycles required is 46079 decimal.
The counter is to be loaded with 65536-46079=19457=4C01Hex
TH0=04CH and TL0=01H.
SETB TR0 initiates timing and Polling TF0 gives the end of the required time.
Now the problem is IF Timer 0 is to be configured for the above purpose, What should be TMOD value?
TMOD = 01010001B configures this but also configures Timer 1 as counter !!
If timer 1 is not to be configure what should be the TMOD value.
A simple explanation of these setting will be of help.
MOV TMOD,#01010001B ; TIMER CONFIGURATION
MOV TH0,#4CH ; VALUE IN TH0 FOR 1/20 S DELAY
MOV TL0,#01H ; VALUE IN TL0 FOR 1/20 S DELAY
SETB TR0 ; START TIMER (FOR 1/20 S DELAY)
JNB TF0,$ ; WAIT TILL COUNTING IS OVER
CLR TF0 ; CLEAR TIMER FLAG TF0
RET
