8051 lcd interfacing problem
hashim5003
Junior Member level 2
I am interfacing at89s52 with 16*2 lcd. Problem is that lcd don't shows the character that I have written in the code. it shows some random character or weird character. Plz chk my code if it's correct or not:
#include<reg52.h>
sfr ldata=0x90;
sbit rs=P3^7;
sbit rw=P3^6;
sbit en=P3^5;
void delay()
	TMOD = 0x01;
	TH0 = 0x00;
	TL0 = 0x00;
	TR0 = 1;
	while (TF0==0);
	TF0 = 0;
	TR0 = 0;
void lcdcmd(unsigned char u)
	ldata=u;
	en=1;
	rs=0;
	rw=0;
	delay();
	en=0;
	delay();
void lcddata(unsigned char v)
	ldata=v;
	en=1;
	rs=1;
	rw=0;
	delay();
	en=0;
void lcdini()
	delay();
	lcdcmd(0x30);
	delay();
	delay();
	lcdcmd(0x30);
	delay();
	delay();
	lcdcmd(0x30);
	delay();
	lcdcmd(0x38);
	delay();
	lcdcmd(0x0c);
	delay();
	lcdcmd(0x80);
	delay();
void main()
	lcdini();
	lcddata('A');
	delay();
	lcddata('B');
	delay();
	lcddata('C');
	delay();
	while(1);
I don't know C language because i am an assembly language programmer but in your code i didn't see the busy flag checking before initialization of the lcd.......First of all you should check the busy flag or give a delay of about 20ms before issuing any command...
HI hashim
apply the following changes to your code
void delay(unsigned int ms)  //This I have added you may use your own delay
int i , j
for(i=0 ; i<ms ; i++)
for(j = 0 ; j<1275 ; j++);
}void LCD_init()
lcdcmd(0x38);    // Initialize 2 lines 5*7
lcdcmd(0x0C ) ;  //Cursor OFF
lcdcmd(0x01) ;
lcdcmd(0x06) ;
lcdcmd(0x80) ;
void lcddata(unisgned char data)
{  ladata = data ;  RS = 1 ; RW = 0 ; EN = 1 ; delay(5) ; EN = 0 ;}
void lcdcmd(unsigned char cmd)
{ ldata = data ; RS = 0 ; RW = 0 ; EN =1 ; delay(5) ; EN = 0 ; }
void main()
ladta = 0x00 ;   // Making the PORT as Output which is connected with Data Lines of LCD
//rs = 1 ; rw = 1 ; en = 1 ;
// Also make the pins as OUTPUT which are connected to RS , RW and Enable Pins
LCD_init() ;
delay(1000);
lcddata('A'); delay(100); lcddata('B');
HI hashim
int i , j
}void LCD_init()
lcdcmd(0x01) ;
lcdcmd(0x06) ;
lcdcmd(0x80) ;
void main()
LCD_init() ;
delay(1000);
Tried it. still no difference. showing random characters
one thing i have noticed is that when I power up controller and lcd. it shows correctly for some time and then shows some random character
Apply some delay before each command as JAMLAL also said
like
void LCD_init()
delay(100);  //Try with 20 or 30
delay(100);
lcdcmd(0x01) ; delay(100);
lcdcmd(0x06) ;  delay(100);
lcdcmd(0x80) ; delay(100);
Also Upload any Image if you have of the same if still it is not working
like
void LCD_init()
delay(100);
I will take the image tomorrow.
i have used delays.
could it be the problem of lcd hardware?
