[SOLVED] 8051 interfacing with stepper motor using uln2003
pradeep23
Member level 5
hi everyone i am doing one simple project like 8051 interfacing with stepper motor using the driver ic ULN2003 in this i have connected like 2 inputs (p2.1) (p2.3)and 4 outputs from(p2.13,14,15,16)..................i didnt get the output .........is der anything in that connections or in my program plz help me to do this...............
first is put your circuit diagram and then code on the forum such that one can able to anticipate what is problem ?
RD milind
this was my program for the below circuit...........
#include<reg51.h>
#include<stdio.h>
void delay(){
unsigned char i,j,k;
for(i=0;i<6;i++)
for(j=0;j<255;j++)
for(k=0;k<255;k++);
main()
while(1)
P2=0x0c;
delay();
P2=0x06;
delay();
P2=0x03;
delay();
P2=0x09;
delay();
please help want to change anything from that circuit or in programs..................
See this attachement
The data you are sending to P2 is
1100
0110
0011
1001
So P2^0 and P2^1 will be 00 for first signal
then it becomes 10
then it becomes 11
then it becomes 01
assuming p1 and p2 in the diagram is connected to P2^0 and P2^1
so your uln2003 i/p and hence o/p will be
for 00 it will be 0101
for 10 it will be 1001
for 11 it will be 1010
for 01 it will be 0110
so check if uln2003 o/p sequnce is right for stepper.
if P2^2 and P2^3 is connected to P1 and P2
your signal is
11
01
00
10
uln2003 i/p and o/p will be
1010
0110
0101
1001
if you have connected P2.1 and P2.3
then your mcu o/p is
10
01
01
10
so uln2003 i/p and o/p is
0110
1001
1001
0110
check if uln2003 o/p sequence is right for stepper or not.
uln2003 o/p should be
1100
0110
0011
1001
to drive unipolar properly in full step mode.
and you cannot generate 1100 because
Pin1 = 0 means uln2003 pin 1 = 0 and pin 2 = 1
pin2 = 1 means uln2003 pin 3 = 1 and pin 4 = 0
so you get 0110
http://www.robosense.in/index.php/...r-motor-using-atmel-avr-microcontroller.html
  • stepper_v10.rar
yes sir i done dat about circuit ..........but in that i am using only two inputs for uln2003 and 4 outputs............motor is not running .......what will be the problem...........
Reactions: kewal
    kewal
y dont you use the 4 pins to drive the stepper motor........
but you saw the circuit sir i attached to that one we can use like that............sir
See this sequence
1100
0110
0011
1001
Can you generate the necessary 2 bits to get this o/p
read the above sequence form right to left. 0th byte comes from P2^1, and 3rd byte comes from P2^3.
if the code should be 1100 then how will you generate 2 bits for it.
why to use relays ...........
i attached my circuit in that
any problem in that circuit
Are you driving stepper motor or dc motor? you have used dc motor in simulation.
