8051 crystal frequency?
TheSniper
Member level 3
8051 crystal
hi guys
i have red some where in this forum that we could operate the 8051 MCU at 24 MHz
is that true ?
because i thaught that it operates at 12 MHz max
is it possible!!?
regards
TheSniper (+)
crystal frequency of 8051
There are many producers of microcontrollers based on 8051 core. In time, the core was enhanced in speed (one of the first to do that was Dallas Semiconductor) and there are producers that have products running at 40 Mhz external clock or even higher. Anyway it's a little bit difficult to add peripheral on the data bus at this high speeds due the timing constraints.
    TheSniper
at89s52 crystal
thanks marie65
ok,then what is the highest frequency for the crystal
for the 89c51?
regards
TheSniper (+)
crytal max & 8051
Hi. Look Cygnal site(www.cygnal.com) the made x51 up to 100MIPS.
\http://www2.silabs.com/tgwWebApp/appmanager/tgw/tgwHome;jsessionid=C4JgplMp9qC92XhS81pn16GXJFMpytgLLvQf2TqL4rz3DlnGGdnh!-2099199467?_nfpb=true&_pageLabel=GenericContentPage&contentObjectId=/public/web_content/products/Microcontrollers/Small_Form_Factor/en/SFF_matrix.htm
Best Regards
    TheSniper
crystal 12mhz in used in 8051
Check Maxim's line of 8051, they produce High Speed 8051 and Ultra Highspeed 8051's.
    TheSniper
available crystal frequency for microcontroller
The basic Philips 8951/52/54/58 family has the max clock frequency of 33MHz.
See this link:
    TheSniper
12mhz crystal free sample
from ATMEL like AT89S51, AT89S52, AT89S52 has max frequency 33Mhz
dependent on device mark.
if AT89S52-12 frequency max is 12 Mhz
if AT89S52-24 frequency max is 24 Mhz
if AT89S52-33 frequency max is 33 Mhz
Added after 44 seconds:
    TheSniper
crystal frequency in 8051 microcontrollers
Dont look at the frequency alone!. The operations/cycle is just as important. There are MCU's with 1 operation per cycle (clockcycle) while most of them are 1 operation per 6 or 12 cycles. So a 10Mhz system on 1 op./cycle is just as fast as a 120Mhz 12 cycle/op. If you need a very high speed 8051 concider a 16 bit (AVR or ARM) processor, otherwise you might end up buying extremely fast (expensive and more difficult) periphiral components.
    TheSniper
divide crystal frequency
Yes, not only frequency, but operations/cycle is just as important.
for 8051 family, some like AT89S51 operation/cycle is f crystal divide 12, with 12 Mhz crystal only 1 operation/uS as same as 1 Mhz speed.
if you use Maxim DS80C320, for operation/cycle is Frequency crystal divide 4, so if it have 12 Mhz crystal = 4 operation/uS as same as 4Mhz speed.
    TheSniper
12mhz cycle 8051
try At89C51 series, it can support up to 20MHz.
maximum frequeny in 8051
what about analog device's mcu of 8051 and 8052 core?I 've receive free sample of aduc841 which is 20mpis.Does it can be programmed with the programmer of commom 8051?
thanks
