8051 controller asm problem
hassan ali
Member level 2
Member level 2
egypt
hi , sorry for my English
i have connected my project (8051 interface with keypad), the keypad output is in decimal,
so by example (if i write 800 using keypad)i want to take this number and then subtract this number from (65535) and then load the counter (TH0 , TL0) with the output result from the subtraction process, how can i do this ?????
note:i am using Assembly language, and i want to do it using Assembly.
first thank u for your reply
but i have already do these previous steps
but i asked for how can i sub the number from 65535 and then take this number to load the counter.
If the number is binary as byte1H and byte1L (that is 16-bit number), the subtraction could be performed as:
MOV A, byte1L
CPL A
ADD A, #1
MOV byte2L, A
MOV A, byte1H
CPL A
ADDC A, #0
MOV byte2H, A
Now byte2H and byte2L hold 65336-byte1H/L
But, if you like instead that byte2H/L = 65335-byte1H/L
MOV A, byte1L
CPL A
MOV byte2L, A
MOV A, byte1H
CPL A
MOV byte2H, A
