8051 C/C++ compiler with double precision support
waligora33
Newbie level 3
Newbie level 3
c++ compiler double precision
Hi all,
Does anybody have an experience with CEIBO c++ compiler which supports double precision numbers in 8051? I mean is this compiler really supports double (64-bit) or just treating it as float?
I need to find some C compiler which works with 8051 and has double precision support.
Any help is really appreciated.
Thanks!
the Keil compiler supports double precision, please declare as FLOAT 64
Bob
hi :)
keil is very good for this, i use it, and also its simulation will help u
bye
Ahmed
Thanks!
I checked Ke*il web site and double type (in PK51) is supported lexically only, and in fact it is compiled as float type 32-bit :(
What you mean as FLOAT 64?
Can you show me what should I change in this simple example.
struct ll{
long e;
long m;
union dll {
double d;
struct ll l;
volatile union dll dv1;
volatile union dll dv2;
volatile union dll dres;
void main()
dv1.d=3.0e50;
dv2.d=4.0e60;
dres.d= dv1.d+dv2.d;
while(1);
Thanks again!
Raisonance compiler has double float too.
Raisonance doesn't support IEEE-754 double, but
it supports BCD type double where mantissa is 5 Bytes and exponent is 6-bit only.
I checked it with actual version of its C 8051 tool.
I'm looking for IEEE-754 double (8 bytes) format support.
Still searching a solution....
Any advise is really apreciated.
