[SOLVED] 8051 AVR programmer problem
your1click
Member level 3
Member level 3
Dubai, United Arab Emirates, United Arab Emirates
If its a problem for only one particular device, verify that the device is not locked with wrong fuse bits in the last event. Try using a brand new device instead. OR cross check for wrong connections to the respective pins from programmer to the device. See that the device is powered with 5 volts.
Cheers
