8 to 0 countdown timer
rayel
Newbie level 5
Newbie level 5
Hi
I was looking at a countdown timer sent in by Metal it was quite a way back 05-08-05 the title was countdown from 8 to 0
I like the ease of the program so I downloaded it then ran it
it ran right off no problems EXCEPT it counts up .What I really need is a count down time with a short code a possible
I am very green at this stuff so any help would be very helpful. Could some lead me to a solution to that program ?
if I get it to work I would like to try a 2 digit countdown timer from 10 to 0 with an output when it reaches 0 then start all over again
What I really am doing is making a 10 min id'r for my radio station when it reaches 0 it will turn on a relay it sets the play button on my radio shack voice module to indentify my station
Thanks for any help
Ray
  • 8 to 0 count down timer.txt
Hi Jay
did you get my post ???
I had to send it 2 times I hope it went through
I noticed that it went to my original post is that the way its done.?
I thought it would go to your reply
Thanks Ray
I can help you with mikroBasic Code.
Jay Im not sure what mikrobasic is but I found a solution . I found that the n array counts from left to right in the lookup statement
so what I did was to reverse the digits order I took the first statement and moved to it to the last and then took the last to the first
I might be confusing you so I'll paste it here
'* Notes reverse (lookup n ) to count down instead of count up *
'* count up) Lookup n, [$40, $79, $24, $30, $19, $12, $02, $78, $00, $18], '
'* count dn) Lookup n, [$18, $00, $78, $02, $12, $19, $30, $24, $79, $40],
it works perfect it counts down from 9 to 0 then brings pin rb7 high for 3 seconds to turn on relay
I'll look into that mikrobasic
Thanks for your help
Ray
