8 KB Data Sending Limit from one PC to other PC (Server/Client) through MATLAB/JAVA
testing test
Member level 3
Member level 3
I am using a code which calls Java inside the .m MATLAB files. Both the .m files are working fine. But the problem is that if I send data greater than 8192 bytes (8 KB) from server to client, like 9000 bytes, the server will send all 9000 bytes to client but the client will pick first 8192 bytes and discard the remaining.
I am placing the codes for both client.m and server.m. I am not that much good with JAVA/Socket Programming. Please let me know what factor is limiting the client to receive only first 8192 bytes and how this limit could be increased?
server.m
% SERVER Write a message over the specified port
% Usage - server(message, output_port, number_of_retries)
function server(message, output_port, number_of_retries)
    import java.net.ServerSocket
    import java.io.*
    if (nargin < 3)
        number_of_retries = 20; % set to -1 for infinite
    end
    retry             = 0;
    server_socket  = [];
    output_socket  = [];
    while true
        retry = retry + 1;
        try
            if ((number_of_retries > 0) && (retry > number_of_retries))
                fprintf(1, 'Too many retries\n');
                break;
            end
            fprintf(1, ['Try %d waiting for client to connect to this ' ...
                        'host on port : %d\n'], retry, output_port);
            % wait for 1 second for client to connect server socket
            server_socket = ServerSocket(output_port);
            server_socket.setSoTimeout(1000);
            output_socket = server_socket.accept;
            fprintf(1, 'Client connected\n');
            output_stream   = output_socket.getOutputStream;
            d_output_stream = DataOutputStream(output_stream);
            % output the data over the DataOutputStream
            % Convert to stream of bytes
            fprintf(1, 'Writing %d bytes\n', length(message))
            d_output_stream.writeBytes(char(message));
            d_output_stream.flush;
            % clean up
            server_socket.close;
            output_socket.close;
            break;
        catch
            if ~isempty(server_socket)
                server_socket.close
            end
            if ~isempty(output_socket)
                output_socket.close
            end
            % pause before retrying
            pause(1);
        end
    end
end
client.m
% CLIENT connect to a server and read a message
% Usage - message = client(host, port, number_of_retries)
function message = client(host, port, number_of_retries)
    import java.net.Socket
    import java.io.*
    if (nargin < 3)
    end
    retry        = 0;
    input_socket = [];
    message      = [];
    while true
        retry = retry + 1;
            break;
        end
        try
            fprintf(1, 'Retry %d connecting to %s:%d\n', ...
                    retry, host, port);
            % throws if unable to connect
            input_socket = Socket(host, port);
            % get a buffered data input stream from the socket
            input_stream   = input_socket.getInputStream;
            d_input_stream = DataInputStream(input_stream);
            fprintf(1, 'Connected to server\n');
            % read data from the socket - wait a short time first
            pause(0.5);
            bytes_available = input_stream.available;
            fprintf(1, 'Reading %d bytes\n', bytes_available);
            message = zeros(1, bytes_available, 'uint8');
            for i = 1:bytes_available
                message(i) = d_input_stream.readByte;
            end
            message = char(message);
            % cleanup
            input_socket.close;
            break;
        catch
            if ~isempty(input_socket)
                input_socket.close;
            end
            pause(1);
        end
    end
end
Thank you in advance for your help.
Bye!
I didn´t find at above code, where had you decladed input_stream variable.
