T
treez
Hello,
Do you think the attached is the best way to do a 7.5kW Charger/Discharger for an Electric Vehicle?
All six LLC converters would use the same transformer spec.
All 12 Boost converters would use the same Inductor spec.
The three discharge Boost converters are in parallel, and have a regulated output voltage, so therefore they need the single external error amplifier between the three of them. (so that they share current equally and don’t oscillate).
An alternative way would be to have three 2.5kW Grid-Tied-Inverters (instead of the one 7.5kW Grid-Tied-Inverter). This would then “modularise” the design nicely, as it would then contain three identical 2.5kW ‘Charge modules’, and three identical 2.5kW ‘Discharge modules’....(and the inconvenience of having the current share circuitry for the three discharge Boost converters then disappears)
(sorry the title should say "7.5kW")
The "Modular" version is also attached, and uses three identical 2.5kW "Charge" modules, and three identical 2.5kW "Discharge" modules.
2.5kW is a good size for a single module because the LLC transformer can be done with a low profile off-the-shelf PQ3535 core, which means the overall module height can be low, meaning that a 'stack' of them isn't too high.
The "module" idea is also good because in both "charge" and "discharge" directions, the module is "output current regulated", which means that the modules can be paralleled without needing any extra current sharing circuitry or inter-connectivity.
