[51] 74HC595 with 16 leds issues
sp2012
Junior Member level 3
Banglore
Hi to all,
I am using 8051 and two 74HC595 shift register to control 16 leds.
In my schematics:
1st HC595 QA to QH connected to 8 leds
and
2nd HC595 QA to QH connected to next 8 leds.
1st HC595 Clock and 2st HC595 Clock pin connect to P1.2
1st HC595 latch and 2st HC595 latch pin connect to P1.3
1st HC595 serial data input connected to P1.4
and 1st HC595 QH'(9th pin) connected to 2nd HC595 serial data(14th pin)
and gnd(8 and 13th pin),vcc(16 and 10th pin) both HC595 given.
Thats all in schematics.
and my code are:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
void delay(int a)
   int i;
   for(i=0;i<a;i++);   //null statement
void HC595_DISPLAY(unsigned char dat)
    HC_LATCH = 0;
    HC_CLK=0;
    for(cnt=0;cnt<8;cnt++)
        HC_DATA     =       dat & 0x01;
        HC_CLK      =       1;
        delay(2);
        HC_CLK      =       0;
        delay(2);
        dat = dat >> 1;
    HC_LATCH = 1;
int main()
    while(1)
        HC595_DISPLAY(0xf0);
Here in my led output
1st HC595 4leds on
and
2nd HC595 4leds on.
I need to toggle one by one leds.
Can anybody guide me how to do this please?
Regards
surya
The following example might do what you want. It should turn on 1 LED at a time in sequence.
#include <mcs51/at89c51ed2.h>
#define HC_LATCH P1_3
#define HC_CLK P1_2
#define HC_DATA P1_4
int cnt;
void delay(int a)
  int i;
  for(i = 0; i < a; i++); //null statement
  HC_LATCH = 0;
  HC_CLK = 0;
  for(cnt = 0; cnt < 16; cnt++)
     HC_DATA = (dat & 0x01);
     HC_CLK = 1;
     delay(2);
     HC_CLK = 0;
     delay(2);
     HC_LATCH = 1;
     delay(2);
     HC_LATCH = 0;
     delay(0x600);  // delay long enough to see LEDS
     dat = dat >> 1;
int main()
  while(1)
    HC595_DISPLAY(0x0001);
do it in a following way :
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
void delay(int a)
   int i;
    HC_LATCH = 0;
    HC_CLK=0;
        HC_CLK      =       1;
        delay(2);
        HC_CLK      =       0;
        delay(2);
        dat = dat >> 1;
    HC_LATCH = 1;
int main()
    while(1)
        HC595_DISPLAY(0x00);
        HC595_DISPLAY(0x01);
        delay (2000);
