Eugen_E
Full Member level 6
I designed a simple PLL frequency multiplier - phase comp II, VCO range 3-6 MHz, divider N=512, 3rd order filter, with the Fairchild 74HC4046 which has an AC input signal sensitivity of 150 mVpp according to the datasheet. The reference signal is capacitor coupled from a PC sound card (5.85-11.718 kHz).
The problem is the loop locks only for signals higher than about 2 Vrms which is the maximum output from the sound card. When it locks the loop is very stable. At lower input signal, the VCO varies between 5-6MHz even with Fref = 5 kHz, so I thought the reference signal is noisy and triggers the phase detector, and I added a simple RC LPF. I also tried using another PC, with the same result.
I apreciate any advice for making this loop lock with a reference signal under 500 mVrms and without a signal amplifier.
