orienteraren
Junior Member level 1
I must do something really really wrong. I set up a simple 741 CN opamp and feed it with +12V on pin 7, -12 V on pin 4, ground both inputs and measure the voltagge on pin 6 compare to ground and I get -11,4 V! If I leave both inputs (pin 2 and 3) open I get 9,8 V. Shouldn´t I get a 0 out in both cases?
I tried to balance it with a trimming pot between pin 1 and 5 and connecting the - 12 V to the slider. At 10kohm I got the output to about -2,8 V but I think I´m doing something fatally wrong here, this should be straight forward!
Ialso tried different physical compnents of the same type and change the feed to +/- 7,5 V and +/-5 V.
What is the problem?
Best Regards
Fredrik
Best Regards
Fredrik
