Verilog Code : 'define & parameter
choonlle
Full Member level 2
AFRICA
verilog parameter
What is the different between parameter and define ??
May u give some examples...
I feel diff to understand the diff between both of them.
Thanks!
verilog define
Parameter is a data type in verilog. It is used to declare constants which are not modified during runtime. Where as we can use defparam statement for updating the parameter.
'define is a macro that can be used to define any variable, function or exprassion under a name. U can use the macro for a given data in ur code with ' identifier
Added after 25 minutes:
Go through this its really useful for beginners
verilog define parameter
`define is a macro. You use it in the same way that you use macros in C language.
A parameter, on the other hand, will become a membor of your module. Imagin you write a code for a generic adder with a WIDTH parameter as the width of its input/output ports. Now, you can instantiate the same adder several times with a different value for the WIDTH parameter.
Example
module adder (a,b,c);
parameter WIDTH = 2; //defult value
input [WIDTH-1:0] a;
input [WIDTH-1:0] b;
output [WIDTH-1:0] c;
assign c=a+b;
endmodule
The instantiation will look like this:
adder #( 4 ) adder1 (a,b,c); // a four bit adder
adder #( 8 ) adder1 (a,b,c); // an eight bit adder
Now, think about it, could you do the above example, using macros?
    abcdsun123
    V
    anhnha
verilog `define
Hi
ourarash is correct
Parameters allows you to have configurable hardware at the compliation time.
defines manily are used as a complier directive (to be used with `ifdef and `ifndef)
Thanks
Haytham
define verilog
thanks a lot
`define verilog
but be careful about the scope. `define is universal...so anything gets compiled and use that `define will get the value.
