cturbo
Newbie level 2
68HC11/FOX11 board Digital Clock Source Code (Need Help)
I need help, to write a source code for the FOX11 board and Micocontroller 68HC11; to use the LCD on the actual FOX11 board to display a digital clock. There is no external components. Below is what I have and what i need is to add the part to have it correctly show on the LCD. I am not proficient enough to get this to work and need help. If this code is not workable please advise. Thank you
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 org 0 ; start address of data hr rmb 1 ;hour counts in bcd min rmb 1 ;minutes count bcd sec rmb 1 ;second count bcd fsec rmb 2 ;fraction of second count for rti routine fcnt equ 244 ;number of rtii interrupts to make 1 second * org $180 *subroutine intitrtii initrtii bset tmsk2, x $40 ; set rtii flag cli clr fsec ; initialize fsec clr fsec+1 rts ; return *service routine rrtii rrti ldx #regbas ldaa #$40 ; clear rtif staa tflg2, x ldy fsec ; count # of rtii iny ;occurrences sty fsec cpy #fcnt ; add 1 to sec if beq second ;enough occurred seconds clr fsec ;reset fraction sec count clr fsec+1 ;to zero ldaa sec adda #1 ;add 1 to second count daa ;adjust for decimal arithmetic cmpa #$60 ;check for seconds = = 60 beq minutes ; adjust minutes if = = 60 staa sec rti minutes clr sec ;reset sec to zero ldaa min adda #1 ;add 1 to minute count daa ;adjust for decimal arithmetic cmpa #$60 ;check for minutes = = 60 beq hours ;adjust hours if = = 60 staa min rti hours clr min ;reset min to zero ldaa hr adda #1 ;add 1 to hour count daa ;adjust for decimal arithmetic staa hr cmpa #$24 ;check for hours = = 24 bne return ;reset to 0 if = = 24 return rti
