Temperature Sensor for 4 Kelvin
archiees
Member level 1
Hi ,
I need to do some gain measurements of my MESFET amplifier at around 4 Kelvin. To measure the temperature I was hoping to buy Silicon diodes from Lakeshore - just realized that they are very expensive ($500 bucks for the calibrated ones). Is there a way i can rig up something in the lab without spending half a grand.
I need to go from aounrd 77 K to 4K with +/- 1 Kelvin error.
cant you buy a cheeper probe made in china
you could also rig up a d-a converter run from an mcu to supply the voltage instead
converting it to current is easy if needed
    archiees
Please,
can you tell me more? What kind and do you have alink to the specs?
if it uses an a-d just use the same resolution of d-a to supply
here is a page i found has some code
{nice and easy in picbasic or something }
use an lcd
or use c language there is lots of free compilers around
    archiees
The lower limit of these sensors is greater than 4 kelvin which is equal to -269 degree celcius. I need to something that will go to that cryogenic temperautres.
