60MHz clock generation
raguna
Junior Member level 3
Earth
Hi all!
How can I generate a (0 to 3.3V) 60MHz sharp edge clock. I can get upto 100MHz sine wave with my function/signal generator. If I use any high speed comparator, there is always an offset( around 0.2V) at the output. Can I have some option/methods for its generation.
Thanks
Try voltage controled oscillator..
it will produce the frequency you want ..
and you can customize it easily..
Thanks
I have simulated a clipping circuit by using a 60MHz 8Vpp sine wave and clipping it using 1N914 diodes at 3.3V, to generate approximately 3.3 VDC square wave. But, when I tried the same with my function generator and PCB, I see that 8Vpp sine is attenuated at that frequency and the does not clip at all. I noticed that the BNC-BNC wire has a huge capacitance ~40pF. Can some one suggest me to solve this issue.
A comparator should not have a significant offset at its output. What comparator are you using?
What is the maximum rise and fall time you can live with?
Put an inductor in parallel with the cable to tune the capacitance out,
chunckey,Did you mean the implementation of the inductor in the picture below?If my assumption is right, why the inductor can tune the capacitance out?
Thank you so much.
One or two transistors can restore the rectangularity of the signal.
They must be chosen for capacity to respond at 60 MHz.
Two are used in the simulation. You may get by with one transistor if you fiddle with values.
The potentiometer alters duty cycle, by shifting the bias level.
