5Vmicro & 3Vmemory interface
anan1975
Member level 3
Member level 3
Noida india
Dear All,
Please suggest hw I can interface a 5V micro with 3V SPI memory.
Thanks,
Anand
segmex
Full Member level 1
level convertor ; just two resistors 1.8k & 4.7k
anan1975
Member level 3
Member level 3
Noida india
Dear sir,
74hct is only a three stage buffer how it can change level,
and in resistor voltage divider only 5 v can be converted to 3v but 3v from spi cant be boosted for micro to a 5 v.
Regards
anand
anan1975
Member level 3
Member level 3
Noida india
tl 4418g is a triple voltage regulator it cant be interface in clock and data interface
wp100
Advanced Member level 6
Prime Meridian
Hi ,
These bi directional translator chips from TI or Analog Devices come in 4 and 8 bit versions, designed to converting voltages and data direction is automatically sensed.
They are reasonably cheap if you can find them in your area, smd only though.
helios31
Junior Member level 1
France
And why not use directly a processor powered with 3V, if choice not fixed ?
For example, with Microchip, consider PIC24 and PIC32 rather than PIC16 or PIC18, they are at similar prices, but give more !
danielciurea
Newbie level 2
Newbie level 2
You can use pic 18LFxxx supplied from 3.3v. In this way you won't have to modify the software (ifalready existing), you only have to check the other i/o pins for correct operations
